Esprit
- Mar 27, 2013
My USB cable used with DA8 has the pins 1 & 4 (power & ground) covered by tape (both connectors: A & B)
Really open to suggestions!
All friends of mine told to me to use an "audio buffer" (I own powered speakers).
I'll try it compared to an active and a passive preamp.
Would a SPL 2Control be a good choice?
Hello,
I have a SPL 2Control, it's very good for the price but I prefer Pass Labs X0.2 or an Audio Analogue VB Bellini preamp...:wink_face:
What 'audio buffer'/pre-amp do you use?
SPL Phonitor 2 looks a good choice as well for my needs.
I'm having trouble getting the DA8 to "plug & play." The first time I plugged it into the computer I got a message saying failed to install driver, but afterwards the computer doesn't recognize it even after turning it on and off, restarting the computer, plugging the USB cable into a different port, etc. It's a work computer so I don't have the administrative privileges to install software. My D100 MKII worked perfectly with no drivers. Help!
DA8 uses USB audio class 2. Windows requires the installation of the proper driver downloaded from Yulong support site. Sorry I cannot put the link here. The Yulong site seems to be offline right now. Try accessing it later and look for the download area of the support pages. Download the JRiver version. Whether you use JRiver MC or not, this is the best driver.
You must have administrator privileges to install any driver.
Please look for the installation and configuration instructions at the Yulong support web pages.
