REVIEW - Yulong Audio Sabre DA8 Reference DAC
Jul 19, 2013 at 6:43 PM Post #16 of 1,613
I will not sleep having remained in doubt, not resolved, Yulong Vs. Matrix
I'm lost: I did not understand from what point of the review, because of the inputs inverted, what I've read before is no longer correct...
Jul 20, 2013 at 1:18 AM Post #18 of 1,613
LOL i have a black DA8 with the TH-900 and the blue wrapping still on the end myself
I meant to take it off but got busy and forgot about doing it. Maybe mentally I just like the blue vs. the chrome underneath?
size]
Tonight, the DA8, set to DAC-only mode, plugged into the L-2 headphone amp and driving TH900s. (Last night it was connected to an F1J driving HE-6s in preamp mode, for volume control necessity.)
This is a good combo! It still lacks the detail and resolution of the PWDII but it gets close enough to be more noticeably enjoyable. Of course, I've got different cans on so that will definitely have an effect on listening impressions. The HE-6s are definitely no slouch in its ability to present detail though, but the TH900s through the L-2 does sound good with the DA8 as DAC-only. Extension on the bottom end has a bit more bloom and sounds slightly rolled off compared to the PWDII. It's a smooth presentation. Soundstage, as project86 stated in his review, is pretty good, extremely close to the PWDII's presentation. Dead Can Dance's Spiritchaser album has a lot of great tracks to test the soundstaging of your gear and it certainly reproduced it as spaciously as I've heard it before.
Overall, if you don't have PWDII $$ to spend on a DAC, you wouldn't do too bad on this unit. It's versatile enough to handle both DAC and headamp/preamp duties. I'd attribute my listening impressions from last night due to my equipment configuration with the F1J+HE-6 and not having a preamp to compare DAC impressions properly across both my setups. You can draw your own conclusions from this.
size]
Jul 20, 2013 at 7:48 AM Post #19 of 1,613
size]
size]
Very nice, sounds like we have similar tastes in music too! I also have a HE-6 but its currently at BTG Audio getting hard-wired. I have a high-end integrated that is pushing it and the clarity and naturalness is the best i've heard short of a TOTL stax setup. I have to admit, the DA8 being able to hang with PWD mkII and Anedio D2 is no small feat from a relative newcomer, very impressive. Enjoy the music my friend! :)
Jul 20, 2013 at 9:20 AM Post #20 of 1,613
Your going to like them hardwired.  What cable did you get?
Jul 20, 2013 at 10:44 AM Post #22 of 1,613
Sorry! It's difficult.... my point was I got all mixed up with my inputs. So I switched to a 2-way A/B comparison between just the Yulong and Matrix, and the Matrix was better... in that particular setup. As I said, there are other configurations I can come up with where DA8 is by far the best, or D2 is definitely superior.
The main thing to take away from the Matrix and DA8 comparison: they don't sound all that different. Someone who heard one and loved it will probably enjoy the other. Or if they disliked one, they probably won't be blown away by the other. So I recommend shopping based on price, features, and availability, with sound being less of a key factor.
Very nice review John, makes it even harder to decide what to upgrade too when I get my Sr-009s in...I'm still thinking Audio-GD Master 7, it was the only dac I heard that I liked more than my D2 when I had it.
Thanks! I gotta try that Master 7 one of these days. Too bad it's soooooo massive, as I don't have much room left in my rack.
size]
size]
Thanks for the update. Extra credit for the Dead Can Dance reference.
Great review as always John.
Finally got to hear how the DA8 compare with D18.
Thanks! D18 remains a very enjoyable device, and would actually fit some people better than DA8.
Jul 20, 2013 at 11:13 AM Post #23 of 1,613
Excellent review. Thank you Project for the detailed and honest presentation.
I wonder how the DA8 compares to the Invicta.
A comparison to the Mytek (which uses a different Sabre chip) would be interesting, too.
Yulong goal was to create a DAC to be better than the Weiss DAC202.
Did he accomplish it? The measurements may show better figures but what about the SQ?
Jul 20, 2013 at 11:14 AM Post #24 of 1,613
Tnx,
have you tested Yulong and Matrix with speakers?
Jul 20, 2013 at 12:14 PM Post #25 of 1,613
DA8 is not on the same level as the Invicta. I love both but Invicta remains my reference, in the grand scheme of things it is higher up. DA8 may compete with some DACs costing 2 or 3 times its price, but so does Invicta. But it's the type of thing where you don't really know what your missing until you hear the better model.
I have very little experience with the DAC202. It wouldn't surprise me if the DA8 sounded better, but I really couldn't say. I recall the Weiss being more clinical.
For the Mytek - I have it on good authority that their device (using the ES9016 which is not seen very often compared to ES9018) is one of the worst measuring implementations of a Sabre DAC. This is not from Yulong but another designer who knows a thing or two about the chips, and measured the Mytek with his Audio Precision rig. It was so bad that they stopped looking into what might be wrong with it.
I know a lot of people enjoy the Mytek, and I have no explanation as to why they love it but others hate it. All I can say is I prefer the DA8 by a large margin.
Tnx,
Yes, but my speaker rig is not as resolving as my headphones. I use the X-Sabre with the AURALiC Taurus over XLR, feeding a NuForce STA-100 and driving Sjofn (the clue) monitors. It's a nice musical system, very involving, but not the last word in details due to my room being terrible. I connect the DA8 via RCA and switch back and forth, and in this system it's pretty much even. Matrix has slightly larger soundstage, more "out of speaker", while DA8 is more precise with imaging.
Jul 20, 2013 at 12:56 PM Post #26 of 1,613
I got a 12 ft. Sunset (all copper, thanks to your recommendation) with banana plugs. Who knows, maybe i'll get crazy and passively bi-amp them :D
Jul 20, 2013 at 2:21 PM Post #28 of 1,613
12ft....:eek:   That's a long cable...
Yeah hehe, I need the length so I can move around and lay down. I can easily snip it later on and re-attach the banana plugs if i desire. One of my pet peeves is being chained to a desk...
Jul 20, 2013 at 2:45 PM Post #29 of 1,613
Matrix wins again
P.S. I have the "wrong" Mytek...
