Kendoji
- Jun 5, 2012
Never mind, I'll know soon enough myself. Just placed my order!
I'd set the V200 as shown in the photos below and, while playing a CD, gradually increase the OPPO DAC volume from 0. (On the OPPO remote, use the volume - + buttons. You can monitor the DAC volume from the display window or on your video display if that is installed.) If more volume is needed change the gain switches on the V200 an start the DAC volume from 0. Remember to turn off the V200 before changing the pre gain switches turn down V200 volume before turning on.
Pre gain set to -6 db below.
Volume knob set to fixed 3:00 o'clock position. (foil tape added to knob)
Really loving how the T1 sounds with the V200 at the 3oc position and the volume driven by the DAC - smoother, more powerful. Such a pleasure.
On the other hand - don't plug your Senn Momentum's in to the V200 - bloats the bass and destroys the sparkle - they sounded bad, even with the lowest Gain setting. Looks like my search for a decent closed headphone for my home office stack continues...
Hello everybody!, Just got V200 AMP. What gain setting do you use with HD800?
What about ground lift switch? You have to open V200 for that I recon...
How much burn in V200 needs? 20 hours? 100 hours? More?
