orys
- Nov 23, 2008
OK. I had to format it in FAT32 so used 32GB SDcard and got it done as FAT32 not avilable in 32GB+ - All good
Nice!
I have a question maybe someone here can help with. My QP1R is loaded with a SD Card that contains over 4,000 .wav songs. I recorded the individual songs from CD's into my computer. Then, copied the songs onto the SD card. Everything works fine. The files sound wonderful on the QP1R.
But, there is a very large volume difference from one song to the next. Some songs are very loud and some songs are not. That's the way the CD's are too. Some have pumped up volume (think Lenny Kravitz) and older ones (like Bob Seger) play back at a much softer volume level. Is there a way to normalize the volume of over 4,000 .wav file songs so that so that they all play at relatively the same volume level? Some software perhaps that could do that? I only have Windows Media Player on my computer, that is how I burned the songs from the CD's to the SD card in the first place.
Hello. Tell me how to fix a very annoying problem. At the moment of low (or medium) charge level, when trying to connect headphones, the player simply turns off. How can I fix this?
Stay updated on Audio-Technica at their sponsor profile on Head-Fi.
If you are trying to sell this item, you are not exactly inspiring confidence by not replying to my text of three weeks ago requesting information that you should have included in your first message. Item location and price. You have made 11 posts since the QP1R advert. If you can't be bothered neither can I. Interest is withdrawn.Location and price?
You should check your PM'sAnyone got a newer style qp1r for sale in the UK in gold?
