T-Willi
- Jul 1, 2011
Thanks man.
I just couldnt find the price anywhere haha.
When using FUN as USB DAC: which player suits best to it?
Currently I play my lossless files with foobar2000 because of it's simplicity but I can hear there the differences between WMP, winamp and foobar. I've never tried j.river.
Quote:brat said:
I had to swap to the J River player when I made the jump from XP-Pro to Win7 Ultimate....when I made that O/S jump Foobar2000 did not have a WASAPI driver as of yet so I was forced to dump Foobar for J River MP 15.XX. I am unsure if Foobar has a Vista/Win7 WASAPI driver yet ...if that has changed there may be zero diff in SQ between the two sw players, then again there might be but I have no idea about that. I do know the Win7 audio section (and USB driver has improved with SP-1) is a major step up from Win XP (any flavor) which is good news.
Peete.
Hmm I took some advice on using the ada4627-1brz with the Fun and the HD650's. Well... it only works for the preamp out and I'm only using the discrete headphone amp of the Fun. The opamp is for dac output, does that mean that the dac output to the built in headphone amp doesn't use the opamp or does?
So i guess my question is , which outputs will be affected by swapping opamps when using the built in dac?
and which outputs will be affected when changing the output buffer module when using the built in dac?
headphone amp? dac output? Preamp output?
HD650 are far from neutral. New HD650 are just terrible
Listen to the MUSIC, not the DETAILS.
As best as I can tell, with the Fun, when using any digital input through the DAC (optical, USB, or coax), all outputs (headphone, variable level preamp, or fixed level DAC) are through the opamp. The only time the opamp isn't in the path is when you're using the analog line inputs instead of the DAC, i.e. you depress the "Line In" button.
Essentially, you're listening through the opamp any time you're listening to the DAC.
(Don't know about the buffer module.)
