- Oct 14, 2013
So can ATH IM-04 hold ground against Shure SE846 ?
Exactly what I thought when I auditioned the IM03 and IM04 (while transiting Singapore, great city btw). The IM04 also has good details in the bass, as good as the LCD-2. The texture and tightness is a little better on the Lcd-2.
Yeah, IM02 is already bright/analytical sounding IEM and probably silver cable may cause sibilance in some songs.
I got the IM02 and IM70 in the mail and I've been listening for a few hours. Firstly, I've determined that my Moto X is what causes the static noise, as I hear it on all the IEMs (though it wasn't present on a set of full sized headphones I listened to one time, so there must be a common factor between the headphones). This is disappointing because I thought getting new IEMs would solve the issue. Also of note is that I tried them with my computer (Asus gaming motherboard with segregated audio processing section). There wasn't much of a difference between how songs sounded on my phone and my computer, except for the static.
I definitely don't like the IM02. I guess it's the analytical sound signature. Vocals sound the worst. Most of the vocals in my music sounded empty/flat/I don't know how to describe it, but not good. The clarity was very good, however, and I definitely heard things I hadn't before from some songs.
The IM70 are much closer to how my Klipsch Image S4i sound, but clearer and somewhat more balanced. Overall, these would be an upgrade that sound better in most cases. However, they don't sound dramatically better.
What I would really want is something with the clarity of the IM02 and a sound signature closer to the IM70 or even the S4. But of course the difficult part is I want it over-the-ear with mic/remote (or replacement cables available like with these). I could try the silver cable on the IM70, but I'm skeptical that it would improve the clarity significantly.
I have the IM04 and GR07BE (I know you want a comparison between the IM02 and GR07BE). Both have a very similar sound signature - lush, warm, slight emphasis on the mids. Where the IM04 pulls ahead is little more Bass impact, details especially in the lower region, bigger soundstage and more pinpoint imaging. You could almost say the IM04 is a bigger brother of the GR07BE. Most people say the IM02 is analytical/bright. So, two different headphone flavours.
Silver plated cable will bring more clarity to the Im70 most definitely....also removing the paper filters will help in a way as well
But will it really be enough? If you had to give a percentage clarity increase, what would you say? (Maybe that's an impossible thing to say.)
If your looking for detail and clairity with natural sounding bass you owe it to yourself to look into GR07BE. I always think theres an upgrade out there and everytime I attempt to, im just reassurred of the greatness of the GR07BE.
If you are on stock tips, I'd recommend you to get UE600 tips or Philips 3590 tips which improve the clarity of IM70s or you can remove the filters as @Whitigir said. Tips rolling does a lot to these IM series.
Looks like it doesn't have mic/remote or removable cable (allowing for third party mic/remote cables).
I think I'm going to stick with the IM70 and get the $25 Lunashops silver cable and remove the filters (Someone said that it's reversible but I can't see how. I poked a hole through it just by poking at it a little.) and maybe that ~$40 Android DAC to try to get rid of the static. I don't think there's anything out there that's over the ear, remote/mic, and sounds clear and balanced for less than $200.(Well, Rock-It Sounds told me they could directly sell me an R50M, but it doesn't have removable cables and I don't really want to take the risk. Though I guess I could sell it if I don't like it? I don't know if the fact that they're impossible to find now would be good or bad for that.)
You can peel the filters off with a neddle. The filters are sticky and has some glue around them. After removing the filters you can stick them onto a paper and store them.
Okay I did that and I don't really hear a difference.
