Review: InEar StageDiver Series
Jan 21, 2020 at 4:20 AM Post #331 of 341
Jan 31, 2020 at 5:56 AM Post #332 of 341
@leaky74 @Rodmunch
If you're on a budget, I'd say it's definitely worth browsing AliExpress these days. I have found and bought some upgrade OEM cables that are used rebranded as stock by better known brands and sold for twice the price. Also worth recommending are some Chi-Fi IEMs. The TinHiFi P1 has an excellent SPC cable with the lowest impedance I have yet measured. It's with MMCX connections by default but I am pretty sure you can find it with 2-Pin also.
The reason you'd want to upgrade from the default cable is because it has noticeable crosstalk. I mentioned this while reviewing the SD5 a while back and when it is clearly audible, it is severe enough to hurt soundstage and layering.
Wow, you’re not wrong; using the left/right channel test on audiocheck(link below), in both cases the channel not being tested is ridiculously audible!
https://www.audiocheck.net/soundtests_headphones.php
Feb 4, 2020 at 3:35 PM Post #333 of 341
Received the Astral cable today; sets the SD5 free from the shackles of the stock cable! Recommended!
Mar 17, 2020 at 6:10 PM Post #334 of 341
Well after testing out the pp8, penta Rais and some other items I ended up with buying the SD5 in mahogany. I read several issues in regards to the stock cable and if you say that these cables improve them, then let's try it out myself! Did this change the sound signature?
May 15, 2020 at 7:56 AM Post #335 of 341
Are the SD2 still well regarded under the $/€500 pricepoint? I'm looking for a neutral/natural sound with balanced armatures (planar is tempting too but I haven't heard of anything really neutral besides the uber pricy LCD4i) to upgrade from my RE400 (which are terrific for the price but have technical limitations inherent to dynamic technology).
May 15, 2020 at 8:26 AM Post #336 of 341
Yes. Probably one of your best no-nonsense bets, along with ER4.
Comfort and ease-of-use are much better compared to the Etys while isolation is nearly as good with a good fit.
FR and isolation measurements: https://www.innerfidelity.com/images/InEarStageDriverSD2.pdf
May 15, 2020 at 9:05 AM Post #337 of 341
May 15, 2020 at 3:57 PM Post #338 of 341
Thanks. I sure like those measurements. I'll probably take the plunge if it's still a reference at this pricepoint.
No worries. Do have in mind that there are 2 different sizes too - the standard SD2 and the slightly smaller SD2S - so it's better if you can try them on first or get them through a place with a good returns policy like Thomann. I used the smaller ones and they fit just fine.
May 15, 2020 at 4:50 PM Post #339 of 341
I will order from Thomann yes, thanks for the tip (if I may say).
Sep 2, 2022 at 12:30 AM Post #341 of 341
What are the differences sonically between the SD-2 and SD-2S
