- Mar 30, 2012
oly got 16 bit an 320 on mine atm, not experinced that yet
Im not sure if anyones have already asked this.
but im really intrigued in the HifiMan HM601 since i want to feel like venturing away from the iPod Classics.
and the looks dont scare me of the player, i think it looks very nice.
But my only concern is its electronic features, which you didnt mention(which isnt too much of a bad thing)
because iTunes remains as my #1 Music archiver as it does a good job keeping my music files in order.
i know the HM601 wont sync to iTunes but could i still be able to put my Songs on the player from itunes?
Thanks for any help!
oh and GREAT review and nice pics!
Hi, I am a newbie. After reading many positive and negative reviews of the 601 in this forum, I bought the 601 to replace my Ipod Touch and is very happy. Sure, no Itunes support is a big step to take, but the reward is well worth it. The UI is pretty straight forward, it is not as daunting as some have suggested. These are not important once I heard the beautiful sounds that came out of the 601. I am now in the process of re-ripping all my music into FLAC (this should occupy all my free time for a while). Thanks for all yours views and reviews.
Got a HM-601 4G today, but installation of the USB driver failed, do not have windows media player installed. does it matter?
Or what can I do?
Bent
Or what can I do?
Bent
[size=12.727272033691406px]I have J-river but have not tried to see if it can [/size][size=12.727272033691406px]recognize[/size][size=12.727272033691406px] the player.[/size]
[size=12.727272033691406px]I do have another problem with it, I can´t turn repeat off. It does have the newest firmware, v0.11. Maybe there is a bug in the firmware or??[/size]
[size=12.727272033691406px]Bent[/size]
I use a Graham Slee Voyager, the sound is superb.
better than my Studio-V.
There is something magical about the line out of the 601, even straight
into a $20k 2 channel set up it holds its own and performs very well.
Thanks for the info. Also, can you guys tell me which headphones to use with the 601? I currently have the RE 262 and I like them a lot, is there a pair out that sounds similar? I've been looking into V-Moda M-80, Sennheiser HD 25-1 II and Sennheiser HD598, do these have good synergy with the 601?
Thanks Mshenay, so I take it that none of the ones I mentioned would match the 601 well. Can you recommend something around $150 that is bright? I like vocals to take center stage and been told that the M80 would do well in that area, is it true?
