- Aug 18, 2007
The only way to connect optical or coax to it would be to get another DAC that accepts optical and coax inputs and feed it into the RCA inputs, something like the Super Pro DAC707 at ALO Audio, or iBasso D10 or Headroom Micro DAC if you are looking for small and not too expensive (just now saw you have a Headroom DAC).
See Currawong's post quoted a little below this spot.
I didn't look for 6J1 tubes since Skylab contacted me after he saw a post I made about needing tubes and offered to sell me a very nice pair of Raytheon 6AK5 equivalent tubes. I understand Little Dot amps use these?
Anyway, the stock tubes I said in my review were still very nice - so, no worries there.
Right, and thanks. The SoundSource menu sound switcher is found at Rogue Amoeba | Quality Audio Software for Mac OS X I think.
I mentioned in the review that it uses 16V AC adapter, so it can't be used on a battery pack. So, since rectification is done internally I suspect it will be the same as with the DACMagic and not improve with a power supply - maybe with a power conditioner in your power strip?
It pairs equally as well with D10 and Pico, but the pico sits on the end-table to the left of my armchair with laptop on my right using a 6 foot USB cable, and the D10 connects with a 6" optical cable, so I didn't have interconnects long enough to reach the EF2 from the D10.
The D10>Gilmore Lite is still a more resolving system, so I can't say how you would like the downgrade. It is certainly transportable - just attach a foam pad to the top with a rubber band, and stick it in your brief case.
Originally Posted by plonter /img/forum/go_quote.gif great review! i really enjoyed reading it. I already have the EF1 and enjoying it very much, but this review makes me want to g et this one too. boy..head-direct sure makes some really nice products, very low price and worth more than that. I just have a question...is there a way to connect a optical or coaxial cable to the EF2 somehow without degrading the signal? I am using a dvd player as transport, and i thought that if one day i would get the EF2 i may want to connect it to it. (although i already got a fine headroom dac i would also like to check the EF2'S built in dac) |
Originally Posted by knugge /img/forum/go_quote.gif Great review. I have a technical question though. I have a Macbook and play my music in itunes. Does itunes automatically send the music out through usb when the dac/amp is connected, or how does it work? |
Originally Posted by plonter /img/forum/go_quote.gif where those 6J1 tubes can be found..? i searched in 2 tubes dealers sites and didn't find this kind of tubes. by the way..how are those stock chinese tubes headphoneaddict? except their brightness, are they listenable with? |
Originally Posted by Currawong /img/forum/go_quote.gif I imagine it's the same other USB DACs -- You open up Audio Midi Setup (in Applications -> Utilities) and select the USB DAC as the output. To make it easier to switch, you can download a menu extra called SoundSource that saves you having to open Audio Midi Setup. Neat looking little amp by the way, and nice review. |
Originally Posted by oxophone /img/forum/go_quote.gif Great job, HPA - as always. Seems like the ideal solution I was looking for. 1. How heavy is the set up - is it portable? 2. Which DAC will pair best with EF2 - PICO or Ibasso D10 ? 3. Would the SQ improve, if fed with a better and clean power supply? Please reply; accordingly, I will make a plan to buy these. |
Originally Posted by myk7000 /img/forum/go_quote.gif Haha I've been waiting for this review. Thanks a bunch! AGHH currently I'm in a quite confused state. I've reduced my cans setup to just a pair of hd600s and I could pocket over 300 dollars by selling my d10->gilmore lite setup and just getting the ef2 but I don't know if I should.... If I travel alot, does this device seem transportable? |
