swbf2cheater
- Aug 14, 2009
does anyone use this with a sansa clip and a Ok1? id love to know how it actually amps off a sansa clip
I have a Sansa Clip (1st gen) with OLED display and I use it 3-5 days a week when exercising. I've had it for 2½ years and the display works/looks as new. I've turned the brightness down a bit to save power.
To be honest I've never seen an OLED display burn out before. I also have a 3 year old iRiver Clix 2 with AMOLED screen and it still works like a charm. As long as you have the option to turn off the screen I don't see a problem here.
Hey guys just a couple questions. Probably been asked many times before but just making sure.
For my home setup right now, I use hje900 or m50 with my laptop. The laptop has a generic soundcard which I assume isn't good at all. If what I been researching about DACs are correct, the e7 should bypass the onboard soundcard and deliver a much better sound? And if eventually I want to upgrade my headphones to a higher end, the e7 would be great to buy because with the the synergy it has with the powerful e9 according to other threads right?
And if I want to use the e7 with my portable set up I need a line-out? But since there isn't one for the zune yet (if what I been researching is true), will it work with the cowon j3 (which I might buy over the holidays)?
Quote:Hey guys just a couple questions. Probably been asked many times before but just making sure.
YES. (for all questions)
err... not really sure about J3 though.
