audionewbi
- Jan 24, 2010
Ck100pro wins on all round. Perhaps the sound is too energetic whereas f111 is a lot easier to listen to.
Go with ck100pro, they are all that, sound stage are not wide but for ba they are great.
Hey. I'm writing because I'm currently eyeing the CK100pro. They do look very tempting, the only thing that worries me is the fit. I've almost only read good things about them. The thing I want to know is, are they still up there with the big boys? Is there any iem in the ~$400 range that beats it? Considering the very good prices on them. I'm looking for a pretty flat response as I have the ASG-2 and UE900 and I'm selling off the GR07 mk II, R-50, Redgiant A03 and Sennheiser IE8 because I don't feel they fill up any spot where I consider them better than ASG-2 and UE900 with 100 ohms added. Should I buy these? I'm almost allergic to the 8kHz sibilance but I like comply tips and find them very comfortable (TS series at least). 10kHz is a lesser problem for me.
CK100pro is not flat. Like always sound is subjective but to me they are the best that I have in my current collection. I had the chance to compare it against 1+2, while 1+2 had deeper bass on all round ck100pro was able to keep up with that iem just fine.
Fit wise I use ortofon tips and I find fit very comfy. the stock silicon tip are rather uncomfortable and gives sibilant to the sound which ortofon fixes.
What part of the sound is not flat-ish? I'm not really looking for ER4S flat but something that's not really exaggerating any part of the spectrum. I know that there is a huge lift in the treble around 10k but I think comply tips would help with that if no silicone tips will do the trick.
Works great with clip+ nothing to worry about.
I recently purchased these and I have to admit they are quickly becoming my favourite IEMs. I definitely prefer them to the Westone 4Rs and Shure SE535s which were both decent, but had one minus point each that put me off keeping them. I do find the isolation on the CK100PROs is better than has been reported provided you get a good fit. To me they're just as good at isolating as the 4Rs and I find them more comfortable. And the bass response is definitely better than the CK100s for those who found it lacking in that IEM.
One thing I am concerned about is how the CK100PROs will sound with a mini MP3 player. I'm currently trying to decide between the Sansa Clip +, the Sony NWZ or the Creative Zen Style M100. Has anyone paired the CK100PROs with any of these players and how did it sound?
