tommo21
- May 7, 2005
Centrance confirms there's no support for UAC1, so that's a bummer. No Slim for me then
I will listen to the most up to date Dragonfly later today or tomorrow if I can.
The responses were worth the wait, thank you. Last question is, how much of a noticeable difference Is there between using the Dacport Slim out vs say an iPhone 6?
Was this the Geek Out Version1 or the current?latest Version 2? Seems the Version 2 is significantly improved over the first version.
I never took to the first version. Very detailed and transparent but lacked didn't sound engaging or musical to me. Lacked fullness and warmth.
So I may really prefer the Dacport Slim. But as for "heft and bite"...what do you mean? When you say fullness it sounds like full mids but when you say heft and bite, sounds like V-shape--bass boost and treble brightness.
Thanks for the review! I wanted to do one myself, but it seems that CEntrance aren't answering my emails at the moment
In regard to harder to drive headphones, are you sure that the HE1000 is a good test of that? I mean, after all, the HE1000 only has a 35 ohm rating, which is closer to portable than anything. Sure, it benefits from power, but it sounds good out of an iPhone 6 as well...
Do you have a K7XX, HD600/650, or a Beyer T90 to pair it up with? That would really test if it was meant for harder to drive headphones, IMO.
Did you ever get a chance to compare to the Dragonfly 1.2? Having a hard time deciding on a DAC/AMP with so many options out there.
Any word on how it pairs with Android devices?
Thank you for the interesting impressions. Have you had a chance to listen to the HD version? If so, how does it compare to the Slim, and to the other DAC/AMPs mentioned?
they are identical chips, the ak4490 but i guess limited performances for marketing purposesAm I missing it here, or it was not mentioned - what exactly DAC chip is used in the Slim? The same Verita, as in HD? Or a different chip?
I decided to join this drop. Hope I'm not disappointed as this will be my first external dac/amp
