panda
- Feb 9, 2006
you use the 303 in conjunction with the cary amp? isn't that a bit thick? you should try to audition the older 306/200
Originally Posted by DannyB /img/forum/go_quote.gif You are correct. I am awaiting the arrival of the DAC and will be happy to pass along impressions. I have the CARY 306SACD and 303/300. I wonder if the Xciter DAC will have a similar sound signature to either of these. Time will tell. |
Originally Posted by DannyB /img/forum/go_quote.gif I have been in contact with Dennis regarding more clarification regarding the Xciter. Dennis was kind enough to explain the following: "In my mind I had a desire to design and produce a desk top compact triode amplifier with low power consumption and absolute glorious triode Cary sound. At the same time I was deep into the design of a stand alone DAC with USB computer compatibility. Therefore I chose the all time favorite mighty 6L6 beam power tube. The 6L6 along with a KT-88 wired in the triode mode has a very similar curve line as a 300B or 2A3. Keeping in mind light weight and compact......." |
Originally Posted by krmathis /img/forum/go_quote.gif Here is the manual, if you want more info.. http://www.caryaudio.com/pdfs/manuals/Xciter_manual.pdf |
Originally Posted by Audio-Omega /img/forum/go_quote.gif I wonder if it is better than Zana Deux. |
