Perhaps not many Roc (Phoenix, C-2C, C2) owners know that by changing bias voltage on your headamp you can "tailor" to certain extent it's sound: [size=x-small]raise bias voltage - brighter, snappier sound; lower bias voltage - smoother, meatier sound... I have found this particularly useful with current hungry headphones (orthos, K701...) which "blossom" with lower bias settings (or, at least, they sound better by my personal preferences).[/size]
[size=x-small]So, for DIY inclined Roc owners who want to experiment and know how to use multimeter:[/size]
- Roc should be turned on and warmed up; no music playing during measurement
- multimeter set to 20V DC
- black probe (crocodile clip) to ground; red probe (clip) to in phase or inverted phase channel measuring point (there are left and right measuring points for in&inverted channels, but just right channel ones are represented on the picture because both left and right testing points of the same phase should show the same bias voltage)
- Roc standard stock bias voltage is ±15V (+15V for in phase channels; -15V for inverted phase channels)
- turning the trimpot clockwise - bias voltage increases; turning it counterclockwise - bias voltage decreases
- bias voltage can be adjusted in 15V ± 3-4V range depending on trimpot range
- in phase channels bias voltage should be symmetrical to inverted phase channels bias voltage (f.e. if in phase bias is set to +17V, inverted phase bias should be set to -17V)
My Roc preferred bias voltage is ±12V. YMMV.
...and, of course, you can not hold me responsible for anything that happens or does not happen to your headamp.
