tokka
- Jan 5, 2012
I also observe this for a couple of seconds if I connect the device to power with my headphones on, I'm not sure if this is a big problem though.
@wilflare
yes, still using the amp. any decent electronics shop in your area should have options. as long as its the same voltage and same or higher current you're generally ok.
have the device set on 24bit. it'll work on 16 as well if that's what you're asking
won't comment on upgrade paths. others might have opinions to share.
lol nice to see that someone other than myself is still using it.
don't bother with challenger. there's a decent store on level 2 of SLS. 02-40/41. Just get it from there. I can't remember specs offhand so you'll have to look at the adaptor you have.
Using both. Got too busy irl to continue with the stuff on vrz haha. That plus the whole unsavoury incident...
