RPGWiZaRD
- Jan 31, 2010
You sure like to spam those links in every thread M50 pops up. As much as you love the M50 they aren't great for every1, I sold mine after a week.
This review was great, I have been recomended both of these for my budget and listening preference and i was trying to find which one should fit me best. From this review it really seems that hfi-580 is the better choice for me. I love bass but i rather have a balance then the bass being to powerfull. Great review and this helped me choose a lot
Are the M50's that much more comfortable than the 580's?
Have you tried the different pads? Because it might/probably will cause serious sound problems.
My experience with the Ultrasone Pro models you can't change the pads only use the pads they come with or replacement versions of that model.
Even the Edition 10 had a pad defect which hindered it.
So it only leaves me to conclude you can't use any other pads than what it's suppose to use with Ultrasones.
I'm lost, do the M50s have bass comparable to the 580? I know they probably can't touch the XB500, but if they do have a fair amount of booming bass, I wouldn't mind trying them out.
