ZorgDK
- Dec 5, 2010
Do you know if the D1 has phono-specific input so I can connect my turntable to it?
EDIT: Doesn't look like it.
Yoga, Yes it would defintely be over kill, I think it's overkill even with hd650's, headphone's are where you will find the biggest differences, I think you shouldn't really be looking at something this expensive until you are at hd800/lcd-2 standard.
I think I'll get a cheap phono preamp, I see they can be had as low as 30$ from http://www.phonopreamps.com/.
Then I guess that would go into my Lyr amp's RCA input so I would have to switch the RCA cables coming from the DAC whenever I want to listen to the turntable.
