Cool, let us know what you think when you get it.
I personally had a hard time deciding between Yarbo, Sennheiser, and Pailiccs. They all look to be of similar quality so I don't know that it matters much. I'd be curious to see bigger pics of the Yarbo and Pailiccs at some point.
The yarbo plugs feel smooth and solid!!!
the ear guide is awesome, the shape is always there no matter how i try to straighten them
no more irritating stiff memory wire & heat-shrink rubbing against my specs...the 90degree bend is also brilliant
although 1 thing that bothers me is those beat words, its easily scrapped off and also its upside down as can be seen from my pic
Overall, the cable feel likes a springy spaghetti, its feel and texture is different from the traditional es2 cables, i found that its at least a good 15cm shorter than my es2
On the SQ aspects, i personally didnt hear much difference between the supreme rose and es2, if any, i only felt it added a slight more bass impact/slam, but thats about it
on a side note, the connectors cant seem to go all the way in, both sides have a little extra sticking out, i believe the pins are slightly longer than the depth of the socket itself?
