Nirmalanow
- Jun 17, 2006
See my later post below for the solution to my problem with the custom molds. Here is the original post about how I was having a problem with them:
I have been really enjoying my Etymotic ER4S especially since I got Apuresound's S cable for them. The sound is incredibly close to what I get with my AT-W1000s combined with the Echofone (a kind of supertweeter for headphones, see my review here: http://www.head-fi.org/forums/f4/ech...paired-278315/)
So I decided to splurge and get a set of custom earmolds from Westone for the ER4. All went well, I got my impressions made locally, the molds came and are very comfortable with an apparently good seal. But something wasn't right anymore with the sound. It seems like a little bit less of everything. Less detail and clarity, and also less body and warmth to the tone. I am a detail junkie and I really miss the startling presence and aliveness I am used to with the Etys. I would say there is a 10-15% reduction in the details with the custom earmolds. They do place the speakers in the Etys a little further away from my ear drum, and also have a longer "tunnel" for the sound to travel through than there is with the tri-flange tips, so that probably explains the change in SQ. The sound is also slightly lower in volume, but I could not really get back the detail and clarity even when I am careful to equalize volume levels.
I don't think it is purely a problem with the seal, as there is still a similar amount of bass, unlike when I haven't got the regular tri-flange tips seated well and the bass drops out. But I may try and get another fitting to be sure, since I tried getting my money back from Westone, and they were not willing to even talk about it with me. They referred me to the local supplier and the local folks said there was no way they could get their money back from Westone on a custom product.
Has anyone else noticed a change in the sound of an ER4 with the custom molds from Westone? I may still use them with my Iriver H140 for long plane trips because the comfort is very nice, but for serious listening on my main rig, I will still be using the tri-flange tips.
I use the Etys when I take my newly semi-portable fully battery powered system out in the backyard to listen in the great outdoors. See my thread about my motivation for listening outdoors on the audio asylum here: Isolation Ward
My current setup:
Dell laptop with WMP-11 and Burwen Bobcat software
Kimber usb cable
Headamp Pico used as a USB DAC
JPS labs Superconductor + (Harmonic Tech Magic Link Two on order)
Lisa III
Ety ER4S with Apuresound cable
(or...AT-w1000s with Echofone and Aura Bass Cushion when I am inside and plugged in -the Echofone and Aura are not portable)
My current setup:
Kimber usb cable
Lisa III
