How do you think the schiit asgart + HRT MusicStreamer II compares t the NFB15 or 12.1? While I was looking for an open can inder 400, I was a bit skeptical about the srh1440 because the highs are said to be very bright while I prefer forward mids and smooth highs. do you think the dalethorn mod will fix this problem with the treble and make the sound smoother? There's also something else I would like to ask, I have no idea how to dismantle or customize a headphone at all, so will modding possibly ruin my headphone if I don't do it properly? What if I dismantle it and can't put the pieces back together? I wouldn't want to risk ruining a 400 dollar headphone....
Sorry, I didn't have asgart and HRT MS2, so I cannot compare it. Yes, SRH1440 are very bright, but that's the problem almost all shure headphones. SRH1440 are even a bit brighter, than 940, and that's not for everyone. The problem is, as mentioned in some 940 mods, the driver is too close to the ear, there's almost no space between... in fact, velour pads are very soft and shallow, so your ear basically touch the foam, and right under that foam is driver, like 1mm away.
You can eighter move headphones in other position, to make more distance. There are several tricks to reduce brightness for 940, but it works also on other shure headphones, just search of it. Then, there is a mod, that will make more space in earpad, but putting some cotton buds under earpad. It will make more space there (help basses), and make driver to be more distant, which reduce brightness.
Lastly, you can make that foam mod... I've just finished it yesterday, and it worked. One layer of foam will reduce only a bit of brightness, keeping most of details. Two layers of foam (as suggested in dalethorn mod) cutted the brightness significaly, and it is not anymore agressive in any way. But it dumped a sound a little bit, in my opinion. The highs are like distant, some clarity and detail in mids is missing. Basses stood pretty much untouched, I didn't noticed, it helped them. What help basses on shure headphones, is to make more space inside earpad, to make earpad less shallow.
I'm still not convinced, if I like dalethorn mod, and i need to play with it a little. Maybe, 1,5 layers of foam would be better, but unfortunately, it's not possible.
One advice, do not take NFB12.1, I would go for NFB15, which has better transmision over USB, and a little bit imrpoved sound.
