Measuring the Unexpected
Okay. Is that enough? No. Let’s go deeper, and talk about one of the measurements we do that is off the beaten path. This measurement appears to correlate at least loosely to subjective impressions, and it unearths some surprising problems in gear that otherwise measures very well.
“So why not release it for the world?” you ask. “If this is such a breakthrough, everyone should be using it!”
Well, we’re not sure it’s a breakthrough. Our sample size is very small. And any correlation it has with sonics is loose at best. And it won’t matter for the hard-core objectivists who have decided that there are no sonic differences between competently designed components, no way, no how, nuh-uh.
And it’s not a breakthrough test. It’s a simple extension of the old IMD idea, but this time with three, four, or five sines—a multitone distortion test. The theory is the same as IMD—can we reveal non-harmonically related stuff with a more complex signal? Usually we use four tones, ranging from 50 Hz to 15,000 Hz, but we’ve run more and less. We’ve used different tones. We’re still playing with this, so don’t take it as gospel.
Aside: it is dead-easy to set up a multitone test on the Stanfords, but I’m not sure how easy it is to do on other products.
So what do we see when we do multitone tests? More non-harmonically related stuff in designs that sound not so hot. Sometimes in very surprising places…not even related to the beat frequencies themselves. Like the example of the Perfect DAC.
The Perfect DAC was not one of ours. It was sent to us by a friend who wanted to get some measurements for it. This was a delta-sigma DAC, manufacturer and chipset redacted, with a very fancy power supply and all the buzzword-compliant stuff people like to hear about these days. We said, “Sure, why not.” And ran it through its paces.
And…in terms of standard measurements, this DAC blew everything we’ve ever measured away. I mean, vanishingly low noise floor, virtually undetectable power supply harmonics, insanely low THD, flat frequency response…
…until you looked at the IMD, which gave numbers a bit higher than you’d expect, given the THD results. And the numbers weren’t related to the 1K spike…they appeared down low, below 100Hz.
What? We ran through our multitone test (it’s easy to do digital multitones on a Stanford as well, not sure about other analyzers) and the low-frequency numbers went bonkers. As in, there was a broad range of non-harmonically related distortion components from 10-90 Hz, at a fairly high level (-50dB or so). -50dB is potentially audible. And it was up nearly 90dB from the baseline measurement.
So what happened? I don’t know. With digital, there are more variables, and noise-shaping and decimation are math-intensive, algorithmically based operations. Perhaps there’s a glitch in their algorithm. I don’t know. It’s not our DAC, and it’s not something we were going to spend the time to dive into.
So…while we putter around confidently with all of the accepted measurements, maybe there are still realms out there where “here be there monsters.”
That’s why we still listen. And measure. And come up with new measurements. And listen again.
