Questyle m12 popping / snapping sound. Any fix ?
Jan 7, 2024 at 1:18 AM Thread Starter Post #1 of 4
brjoon1021
Earth
Hi,
Just got my m12. It is going into a 50 ohm preamp. There is a nasty popping / snapping noise that happens regularly. I have changed cables, etc... I can play the DC04Pro with the exact same setting and it works fine.
This is with UAPP. for some reason I cannot get it to play at all with HIBY music player. I keep getting a file not supported kind of message when streaming qobuz in the HIBY music app. (which is also odd)
Any help would be appreciated.
Jan 7, 2024 at 1:32 AM Post #2 of 4
Have you tried lowering the volume in case it's clipping? Drop the volume on it to 50 percent, and if the noise goes away, nudge it up a little at a time until it starts happening.
Jan 7, 2024 at 5:17 PM Post #4 of 4
Been messing with this for a while now. Not very thrilled with it. Will only work with one of my USB cables, well enough, but still has small pops. Really finicky device. I think I will return it or trade it.
