Prog Rock Man
- Jul 2, 2009
What are the reasons why two different cables will sound different from each other?
Is capacitance, inductance or resistance the main reason? Is it the way that the cable is made, silver/copper, solid core/litz?
Then, can those differences be correlated, e.g silver has more bass than copper, litz sounds more neutral than solid core?
Then can the way expensive cables are made be repeated with cheaper cables which will make the same sound?
