skhan007
Hello All,
I've bought a couple of the King Crimson box sets and single 40th anniversary reissues. Contained, are discs (DVD-A and BluRay) that have hi-res tracks in 24/96. However, my two BluRay players (Sony and Panasonic) will output these tracks no higher than 24/48, according to the clock on my RME ADI2. I called RME support and they said it's definitely the player downsampling the resolution.
Regardless of how I adjust the audio settings on the players (e.g. selecting PCM instead of Bitstream, etc.) the clock on the RME continues to show it's receiving lower resolution than what the disc is meant to provide. I've tried both optical and coax to connect the player to my RME.
Main question: Do I need a higher-end or special BluRay player to play the LPCM and MLP 24/96 files?
I called Crutchfield and while the tech did not know why my current players were not up the task of hi-res, he recommended I look into the Panasonic DP-UB820 ($399 USD) for an "audiophile level" BluRay player at the entry-level.
Thank you in advance!!!
