Google translation (did a pretty decent job I think):
Tube amplifier for electrostatic headphones
preliminary Information
The SRM-T2 is designed not only as an amplifier for use with the "pro" of Stax electrostatic speakers, but without even a passive attitude Selektoreinheit amplifier. You can switch between different line level inputs.
*** The developed devices for high-fidelity dual triode 7308(6DJ8 equivalent) is used in the first amplifier stage, while the EL is reliable 34 (6CA7) used in the output stage.
*** As usual with Stax developments were everywhere whereit is possible, non-magnetic parts used in addition to the non-magnetic housing
*** The electronic components are resistant to aging and were selected for high tonal quality to
*** Neither transformers are still push-pull amplifier used in the SRM-T2. This also applies to the balanced XLR inputcircuit, in the SRM-T2 is a purist balanced integrated amplifier, which is responsible together with the dual-axis quadruple Lautstärkepegler for the sound quality.
*** The various inputs (3x phono, 1xXLR) can be selected by the input selector on the front
side. The signal can be passed on to the main amplifier of the system, so that the SRM-T2 can also be used as a high quality input selector.
*** In order to ensure the high fidelity, the system is housed in two cases, once the main unit of SRM-T2, and secondly as a power supply SPS-T2
Specifications
Balanced Amplifier in Class-A technology for electrostatic ear speakers with passive selector function
Inputs 3 x RCA, 1 x XLR
Frequency range 1 Hz-70 kHz dB at an SR-Omega
Nominal input level 630 mV at 630 V output
Maximum output voltage 630 V r.m.s. / 1kHz
Maximum input level 30 V r.m.s. (at minimum volume)
Gain 60 dB (1000 times)
THD> 0.01% (1kHz/630mVr.ms in an SR-Omega)
Input impedance 50 k ohms or 100 k ohms (balanced input)
Polarization voltage 580 V DC
Power consumption 200 W (operating) 17 W (standby)
Ambient temperature 5 degrees to 35 degrees Celsius
Protection against moisture be guaranteed
Main unit dimensions 282x162x438 (WxHxD / mm)
PSU 212x138x420 (WxHxD / mm)
Weight (mass) main part 8 kg, 12 kg Power Supply
