JohnFerrier
- Aug 31, 2003
Okay, L. The quick answer is that it depends upon your wiring. Compared to R, it will be small. Guess, it will be less than 1uH. However, you will need to calculate this based on the wire gauge size and length. For your test, just replicate what you have or plan to use.
C is more involved. However, I'll say (and this is only the amplifier) (<50pF || OP27 bypass caps). (And there are no bypass caps on Gilmore's schematics.)
So:
<1uH + (65-234 ohms || (<50pF || OP27 bypass caps))
What did everyone else come up with?
And I notice that no one can tell me what they are using for a volume control. Is is 10k, 20k, or 50k? This is also not in Gilmore's description. Isn't this an easy answer for someone?
JF
Originally posted by alsq not even a puff (small capacitance in the junctions)? or a little, tiny inductance? [edit] whoops! my PC crashed. OK, back to asking inane questions. When the load on the class A finals is not resistive, there are phase issues associated with it. That should affects also the PSU, and that's the part that makes life interesting. How can that be put into the picture? When very small signals are amplified, disphasing the PSU is about neglegible. When large signals are, that is no more neglegible. How can one account for all this, or at least approximate it, using something like Dimitry test rig? Brainstorm! |
So:
JF
