i luvmusic 2
- Aug 27, 2013
You should try the Q701 with Vintage Receiver speaker taps.
Well, I'd recommend applying extra caution when doing that.
Using speaker taps is only safe with balanced headphones, otherwise you may create a short in the amp circuit and generate more smoke than music.
Some amp designs may be OK with that, but unless you are sure or don't really need the amp, stick to what you know for sure.
Anyway, while I don't mind the long 9' cable as I can snake it behind my monitors, I did order a 1.2m 5N OCC cable from eBay. I have the same cable for my HD598 and it sounds freaking fantastic!
I will report back once this bad-boy arrives!
The Q701 has the same original cable inside it, so why changing cable will do anything better?
The Q701 has an OFC cable, not OCC.
Well, I've been very critical of the Q701s from time to time, but here I am, away from home, listening to classic Bernard Haitink/Concertgebouw recordings (at the moment Beethoven Violin Concerto with Krebbers) from the Oppo BD105 - Chord Hugo - Schitt Vali 2 and the sound is CRAZY good. So nice to be proved wrong, especially when it's in the right direction.
Bad afterthought: "Oh God, I'm going to want the K812 now!"
I'am not EE but my PIONEER SX-3700,SA-7700 with my resistor network is fine no smoke so far,The good amp that i have for my Q701 is the Bottlehead S.E.X. however the sound of these amp is no where near as good as my vintage.
I've had two headphones dt770 dt880 250 version
dt770 problem with midranges and SoundStage
dt880 problem with the SoundStage and Treble
Now q701 bought for SoundStage
While the larger SoundStage of the dt880 but not too wide and huge
To reach a hug SoundStage and a wider and deeper What should I do?
I heard that Fiio products have a narrow SoundStage. I have a Fiio e10k
Where is the problem?
To a great improvement (under $ 200):
Buy k701
Buy ad900x
Buy Amplifier
Buy DAC (Modi 2) or ...
And...
Thanks
Soundstage is very recording dependant
Try this samples
http://www.hdtracks.com/sessions-from-the-17th-ward-binaural-278260
It was great, thank you
You mean is that any way for any significant improvement other than the specific record?
For example, Shania Twain female voice with More instruments in the music
