donunus
- Nov 12, 2004
How is this supposed to be tested other than running the headphones to levels where they distort. Isnt that the point where the amp is maxxed out?
Based on those numbers, these cans shouldn't be distorting. maybe it is due to burn in after all. well see
Question, recently I got an HD598 and as I improve sources on the HD598's, the better it gets.
Example:
HD598's plugged into the FiiO X3, it sounds congested and boring.
Through the ODAC/O2, mids/trebles become clear and bass is tight.
Through a tube amp Dared MP5, the thing becomes the tightest bass punching headphone.
Is there a such upgrade I will hear with the AKG Q701's if I got a more expensive source?
Any DAC/Amp combos you guys recommend around $100 for the Q701? I'm running mine out of a Xonar DGX and it sounds glorious, but apparently it can get a lot better from here. It would be nice if I can get tubes around that price, but that might be a stretch to ask for. Thanks.
If you already have an upgraded sound card (like not the onboard sound), no DAC at that price is going to be an improvement, not even the Modi. I'd just spend that money on an amp.
The cheapest tube amps I've seen recommended for the Q are the Little Dot I+ and the Schiit Vali.
Thanks. I was under the impression that amps don't really improve potential resolution increase but rather make the sound louder with very little added color, but if you think they would really improve speed/soundstage or what not when fed by the DGX then that makes more sense.
