i luvmusic 2
- Aug 27, 2013
I heard a lot of good things about Audio gd product however at the same time they have some firmware issue for their product.I end up getting the TEAC -UD-H01.
Thank for this. I was thinking that the Schiit Modi might be a good entry level DAC for a first buy. I am after all just starting out, but am yet to commit to a purchase as I can't choose between the USB version or the optical version. One thing I noticed about the Audio-GD NFB is that it sports both Optical and USB inputs. This puts it at a real advantage, at least compatibility wise, to the Modi which only has either USB or optical option.
So I was reccommended to get the AKG Annie earpads for my Q701 for comfort issues and came across a thread that says parts have to be ordered through contacting a person name Frank Rodriquez, someone who works in the spare parts depart. When I check the akg website, the representative for spare parts is under the name of Marlon Gonzalez. Did things changed? If so, should I still email Frank or this new representative?
Yes, the dual inputs is a huge advantage. The other thing is that the Audio-GD sounds significantly better than the Modi. It's in another price bracket and it sounds like it. If you have the budget to move up, it's a no-brainer IMO. If budget is an issue, the Modi is perfectly acceptable for an entry-level DAC.
Thanks, I just visited the Audio GD NFB 15 series forums. People seem to really like it and according to someone who purchased it last week the price of this unit including shipping to the UK is just about $300, which is not that much more that the Vali/Modi at all. Therefore I am definitely keen to know more about this product. Just wondering why everyone is constantly singing and praising the Vali/Modi stack and the M-Stage but the Audio GD NFB 11/15. You are the first to recommend it to me specifically to drive the Q701s.
I wouldn't recommend spending too much on amps and dacs in general. If you want to improve your rig the most cost efficient way is to upgrade your headphone. I great amp/dac isn't going to change your Q701 into an HD800.
And yet it's said the HD-800s are really amp picky. Also, wouldn't they deserve a nice DAC? Seems like a slippery slope
True, but some people reported good results with just a Vali. Most headphones don't have the resolving power to distinguish between upstream gear and recordings like a HD800, plus most people who buy an HD800 have the dough or are willing to spend upwards of $1000 for an amp.
I upgraded from Q701 to HD800 when I have just the Magni/Modi schiit stack and use it to drive the HD800 for about a month
And how are you liking it so far?
It's clean, powerful, detailed, and musical. Perfect on every count for the Q701's.
