dweaver
- Dec 23, 2008
I use my D1 with my Q701 all the time and it works very well in my opinion.
So I've been told by a retailer that thewill improve the sound of the Q701's. True or false? I don't even know anymore about the depths of the audiophile world.
Then there's the ATH-A900X forum where a guy modded his A900X cables and it sounds better.
I'm just feeling a bit disappointed that the headphones don't come with the best cables after all the money that has been spent on them.
Maybe i should start making cables for Q i might get rich.
If you can solder you can make the cable for waaaayyyy cheaper than buying a made up cable for Q.Mogami 2832 cable $1.26/ ft(this cable is 4 conductors this is what i used)550 paracord $5.99/50 ft. plugs your choice and a bit of know how that's how cheap to make your own cable.
I think what you need to start making are those stands
On the cable front, the stock cables are good. I prefer my DIY, as it does seem a little... what? clearer? more detailed? Something along those lines. And because I could control length and color. I had Redco make me one, but I was unaware of AKG's non-standard wiring, so they wired it the standard way. Left and right were switched. I cut it up and made short interconnects for my Stack o' Schiit, which look pretty good with the white Techflex.
I got Mogami W2799 (4-conductor; thin and supple when stripped of sheath and shield) for $0.64/foot from Redco. That's $0.16/foot per wire.
I'm just feeling a bit more disappointed that the headphones don't come with a comfortable headband and better ear pads and bass optimisation, after all the money that has been spent on them.
