Evshrug - Thanks for the tip on the iDo. Half the price of the iStreamer, and yes if it will work with an iPod classic then it'll work with the Nano. They are the same things, just different sized packages. And I love NuForce, there stuff is always well made, if not "the best" unit. And their prices are always really fair for what you get.
I just read NuForce's page, they officially support the 6th gen Nano, and though it's unlisted I bet others would be supported as well. Since I don't have a nano, but I found out the USB CCK is currently working with audio and iPhones in iOS 7, I'm probably going to get a Modi to use with my computer and CCK "hack." Still, the simplicity and reviews of the iDo are highly attractive.
Ashade & Chicolom - Have you guys heard the K/Q 7xx with a tube amp? The big reason I didn't keep my, say, O2, and shy away from solid-state amps in general with my K702 (and will with my Q701) is that they highlight the analytical nature of these cans, and can introduce some harshness in the upper end. But any tube amp I've ever used them with has alwas solved this issue. (The M-Stage also didn't have this issue; it sounded more "tube like" but had a tendency to shorten sustain and mask detail, things any quality tube amp I've used - including even the Starving Student hybrid - never did).
My tube amp has been my fav so far, for the reasons you mentioned above PLUS soundstage seemed improved and more even. My K712 for some reason isn't liking the tube I have in my amp now, so I'm going to swap that back to my fav.
Evshrug (again) - dude, I'm drooling all over my nice sweater waiting for this Q vs modded Q vs K712 review! I suggest you order Chinese takeout, call in sick, give your significant other a gift certificate for the local spa, and get to work on these comparisons!
Well, I have the day off today, only commitment is a goodbye dinner with the grandparents. We'll see if I'm up for a second head-to-head after my MA900 vs Q701 head-to-head. I like Chinese takeout.
Big Bird - I don't mean to rain on any parades, and I might be wrong, but... I don't think any DAC/amp combo in that price range is really gonna be much good. Especially with a Q701 or any K7xx model. They are notoriously difficult to drive!
My advice to you, would be to order a custom CMoy amp from BioScienceGeek (BSG for short around here) off eBay. His amps are the best portables I've ever heard, personally. Better even than NuForce's great stuff. And they're dirt cheap - like $50 ish. You can also tell him exactly the headphones you'll be using, and the type of music and you're mainly into, and choose the case. He builds to order. The one I have is the best sounding amp period with my Etymotics, for example. I find it comparable in quality, (if not sound signature), to my $800 Glow Audio amp! And the 9-volt battery option makes it super portable and convenient too.
Later, when you've got some bucks together, invest in a great DAC for your Mac ($200 - 250, or the new Glow Audio one at only $125), and then later a super amp that better matches the demands of the K/Q headphones, which are demanding and need a pricier amp. The Matrix M-Stage is a great start for $200 used / $300 new, and then up toward a Schiit Lyr ($450), or Garage1217 Amber ($300) or upper-end tube amp like a Woo Audio 6 or a Glow Audio Amp One ($700/800).
I find, and I think most people here would agree, it's better to sink money into just one quality component and move up slowly, than to spread money out over several lower quality units. Especially as the Q/K7xx are so demanding and picky with amps.
Agree with these final points... I'm currently not tempted to upgrade from my K712, or my very nice amp, but even though I enjoyed my headphone before I got the tube amp I was wanting more from my cheap amp. The good part about buying cheaper components is that you get some instant gratification in the short run, and you can maybe try a few to see what kind of "flavor" you're seeking (transparent vs colored), but the bad part is they can give you a poor representation of the maximum capabilities of other components in your system, and the money you spend on "hold me over" things is that much more money you need to set aside for the component you really wanted in the first place.
LOL, no worries. I'm generally getting thirsty around 6-7 PM, so yeah, Thirst On
Great! No hurry, of course. Appreciate the effort.
I'm about to order the 712 cushions. Hope it's a good change. I guess that's another test you could do, if you haven't already: swap in the K712 cushions on the Q701, at least for your own amusement.
Lol, are you part of the Fantastic 5? The Human Torch's long-lost twin brother?
And yeah, I thought it was a given that if I changed pads on one I'd try changed pads on the other. Many variables, but we gotta take them one at a time...
