For who have compared different DACs , do you bothered doing some level matching ? They don't have a line out output exactly at 2.0v some a bit less , some a bit more => result audio level is not exactly the same , and at hear some times it's not noticeable .
Just to remember , before doing level matching all dacs sounded different , ODAC , Pioneer DVD Player (PCM1754+OPA4580 inside) , A-GD NFB-2 /17.2 .
(The Audio-GDs have different filters some roll of highs , and graphs show it , i had the impression that it indeed had a slight impact on sound but peraphs placebo , but i just used a filter that didn't roll of for a better comparison) .
Well level matching : (playing a Constant Tone , ajusting volume digitaly) ( a cheap decibel meter help) and done . = All sounded the Same ... So if you don't do level matching it will obviously sound different , but in other hand , it don't mean that all DACs will sound the same after level matching . In only tryed some , and motherboard line out from Desktop or laptop computer sounded clearly inferior to the other DACs . Some line out are very close to 2.0 so yeah your impression could be correct and not biased .
But if no level matching there is always a doubt ^^ . And yes we all hear differently so if i don't hear difference itdon't mean that you can't hear it too
Furthemore all my head amps sounded different ... but at this time for now i lost faith in DACs , peraphs i should try some other , even expensive one , but if it's to be disapointed , i guess i better to save money and play with phones and amps
