intlsubband
Which have the biggest amount of space for ears and the biggest pads? I was going to buy some M4u2 but was a bit put off by the build quality problems, if they are a bit brighter than the hp50, have more bass and fit better, then I would probably like them, anyway I will be getting the Shure SRH 1540 tomorrow so might make the decision for me, but if I don't like them for some reason the M4u2 look interesting... IF the pads are a bit bigger / deeper and more comfortable than the HP50, or possibly work with other pads from another manufacturer?
I have both with me now (I gave the HP50 to my workmate who sits next to me), here are some further impressions:
1. pads size - they really are very close in size. HP50 pads a bit firmer / M4U2 a bit squishier. I feel that both encapsulate the ear very well, maybe a tiny bit of extra room in the HP50, but I feel like the M4U2 has a slightly better seal. Neither of these have the biggest earpads and I don't know which aftermarket pads may fit these ,but both are enveloping the ears very well and both work very well as portable over-ears: comfy and a good seal.
2. Headband, design, and comfort - the HP50 are significantly lighter, but I actually find the M4U2 more comfortable. Especially because of the headband - it is padded very well and rests very comfortobly on the top of the head, while the HP50's headband rests a bit strangely on the head and can get slightly uncomfortable after awhile. I don't have any issues with the extra weight of the M4U2 as the design makes it super comfy, and I never had any comfort issues. Although maybe I'm less sensitive to weight of headphones compared to other users, based on reviews of other headphones (I have no problem with the HE-500's weight for example, while some others do).
3. Portability - again, despite the M4U2 clearly being heavier, it actually folds much better and can fit in a smaller case much more easily.
4. Sound - Listening again back and forth between the two, the sound is quite close. All the details are there in the HP50, but in general, the M4U2 sounds lusher and more full-bodied, while the HP50 sounds a bit weaker, if that makes any sense. The M4U2 has just got this touch of lushness to the mids that I'm just addicted to. I think the treble in both is very similar, detailed enough and satisfying, but neither of these is overtly bright.
I never listened to the Shure so I can't compare.
