PSB M4U1 - Thoughts?
- Thread starter swmtnbiker
- Tags
- psb-m4u-1
Zenrap518
- Jan 11, 2017
Yeah... i cant find a Y cable that isn't 2.5mm or XLR... Im just gonna get a normal 3.5mm OCC. Also, it says on the listing that the cable has either silver Oyaide or MPS headphone jacks. Is that fine?
Thanks
Thanks
JWolf
- May 3, 2005
Thanks
The cable amterial will be fine. but not as good as it could be because it's not a Y. If you can build a Y or know someone who can build a Y, then you'll have better sound.
Zenrap518
- Jan 11, 2017
I don't know how to make a Y cable or someone else who can make a Y cable.
JWolf
- May 3, 2005
In that case, I would look on eBay at cables and see who is making custom cables at a reasonable price and ask if a custom Y-cable can be made.
Zenrap518
- Jan 11, 2017
I don't wanna go through the hassle of that. I'll just get the cable.
Also, which type of jack should i get? And for the Oyaide ones, which end goes into the headphones?
Thanks
Thanks
JWolf
- May 3, 2005
Thanks
I can't say which end goes into the headphones. But after having heard a Y cable, I would go through the hassle. It is worth it.
astenlet
- Jan 13, 2017
I have mine modified so that the right jack on the headphone is terminated and recable the inside so that i can use balance cable on the left jack without the use of a y splitter cable. Also on a side note i have ask some of my friend to tried and listening to it and they said the sound is almost as good as audeze el 8.
florencephile
- Mar 7, 2017
there are plenty of options out there.
JWolf
- May 3, 2005
I had my cable made for me. It's 5N OCC. Sounds quite good. Better than the cables that come with the headphones.
Thanks for the reply, I will make one myself, just wondering did you have to disconnect the wiring between cups within the headphone first?
JWolf
- May 3, 2005
No changes were made to the headphones.
Cool, I'll get on the case. Might even make a balanced one.
JWolf
- May 3, 2005
Let us know what you think of your Y-cable. Thanks.
Toothless
- Oct 23, 2014
I use 2 separated cables and plug in the 2 headphone jacks of a Fiio E7. No difference that I could discern than when listening with single cable
