RedHarlow
- Dec 29, 2013
From what I understood It's possible to use your existing soundcard and fix the existing voice chat problems. All through optical.
Hi will the 5.8 wireless mixamp work for chat well on ps4 with the included chat cable from ASTRO?
Sent from my LG-E980 using Tapatalk
ThanksHi will the 5.8 wireless mixamp work for chat well on ps4 with the included chat cable from ASTRO?
I say no, but worked perfectly with the TB PS4 chat cable.
One last question. So I have the Sennheiser G4me One. The Wireless mixamp comes with the Y adapter. Should I still buy the Sennheiser Y adapter, will it be a better fit or make my headphones sound better? Also, one more time, even with the PS3 chat cable with the wireless mixamp, I still need to buy the Turtle beach cable?
OK thanks. I will find out n Thursday when it arrives.One last question. So I have the Sennheiser G4me One. The Wireless mixamp comes with the Y adapter. Should I still buy the Sennheiser Y adapter, will it be a better fit or make my headphones sound better? Also, one more time, even with the PS3 chat cable with the wireless mixamp, I still need to buy the Turtle beach cable?
I'm confused about the prior response you got because my understanding is that if you have the ps3/4 astro chat cable which is a 3.5 to usb propriety cable and very difficult to find, then you are good to go for chat on both ps3 and ps4. It should not be a problem.
Thanks. I had the Gold headphones and returned them. Positioning isn't too good especially when there is any gunfire or explosions, gets real muddy.I'm confused about the prior response you got because my understanding is that if you have the ps3/4 astro chat cable which is a 3.5 to usb propriety cable and very difficult to find, then you are good to go for chat on both ps3 and ps4. It should not be a problem.
I have the 3.5mm to USB cable and when I used it with my PS4 the volume was too low could barely hear others when chatting and playing online.
I will unsubscribe from this thread as I ended up using the Sony Gold headset and it works great.
Hi
I have read all the issue about using 3.5 mm x 2 for PS4 (the mic not working with Y connector and will be working if using mixamp). What I want to ask, how to connect it with somehow, with more effective? I'm still saving my money for PS4 honestly, but I kinda afraid my headset won't work (my headset is Logitech G230). As long as the sound & mic work well (I don't really care about the surround thing) what should I prepare? Sorry for bad english.
Sony released the 1.7 firmware today. I can confirm that none of our voice chat problem has been fixed. One thing I think changed is If your headset is connected via optical and you try to get the voice chat runnin by usb you still keep the sound from the optical instead of changing to usb sound.
