[Preview] FiiO E18 Kunlun – Surprise, Surprise.
May 24, 2014 at 4:04 AM Post #181 of 251
I have an SGN3 & pair it with an E18 primarily to drive V-Moda M-100's. I've also used it to drive my Sennheiser HD 650's and it does that job well. There's no shortage of power & the sound is very good.
May 26, 2014 at 6:05 PM Post #182 of 251
That was exactly my Combo too...
... until I bought a DX90 and a Focal Spirit Classic.
Note 3 tapatalking....
Jun 17, 2014 at 7:35 PM Post #183 of 251
I am using my E18 with an Samsung S5. So fart it only works with the USB Audio Player. Has this been the case for others?
Jun 26, 2014 at 12:46 AM Post #184 of 251
I got my galaxy S5 and E18 and they work with all the software.
I'm running the PowerAmp Pro, works like a charm.
Also with all other music players.
Jun 26, 2014 at 7:57 AM Post #185 of 251
What version of Android are you running. My S5 only works with the USB Audio Player.
Jun 26, 2014 at 11:11 AM Post #186 of 251
Hi Scott,
Mine is running factory standard + 1 update that came in:
Android 4.4.2
Version: G900FXXU1ANE2
Do not forget to use the correct sequence.
It could be the you'll have to kill your playing app's after you connected the E18 + turned it on.
Then start you music app again.
I hope this can help,
Casper
Jun 26, 2014 at 2:12 PM Post #187 of 251
Ahh that seems to have been my issue, thanks!
Jul 8, 2014 at 1:09 AM Post #188 of 251
Just ordered this with a pair of HD 25-1 II's and a BTG recable. Source will be a Galaxy SIII using Neutron Player and I was wondering if I could still use the DAC with Neutron, and compensate for the treble roll-off with some EQ?
Jul 8, 2014 at 3:35 AM Post #189 of 251
Yes you can. The DAC in the E18 is far superior to the one in the phone. Also, Neutron is the best player too, IMHO. Good luck.
Jul 8, 2014 at 10:38 AM Post #190 of 251
Would you happen to know what frequency to increase and by how much?
Jul 8, 2014 at 10:56 AM Post #191 of 251
I have no idea, that's for you to find out. I wouldn't be too quick to use EQ anyway. Just wait & see how it goes.
Jul 17, 2014 at 9:12 PM Post #194 of 251
  What problems are you running into? I have the One m7 and am considering this amp... I'm wondering if any of the problems might translate to the m7.
I use to use the m7 with the E17 and it worked fine using poweramp until a firmware update. Then I got the E18. It seems the new firmware messed with the USB audio out and it's like that on the m8 as well. I think rooting with a custom ROM or something might be needed.
Jul 18, 2014 at 4:07 PM Post #195 of 251
Thanks for the feedback, I'll keep it in mind that I may need to root the phone.
