Audio46 is an authorized dealer of iFi.
According to iFi:
"The hip-dac replaces the inferior DAC (Digital-to-Analogue Convertor) and amp circuitry in smartphones, tablets, PCs and Macs to vastly improve headphone sound. Its design and performance set it apart from other DAC/headphone amps in its class – connect your playback device via USB, plug in your favourite corded headphones or in-ear monitors and the hip-dac delivers a sound brimming with bold dynamism and fluid refinement, effortlessly engaging the listener with all manner of music. In the home, in the office, on a train or plane – the hip-dac is the music lover’s inseparable friend."
Formats supported: DSD256/128/64, Octa/Quad/Double/Single-Speed DSD
DXD(384/352.8kHz), PCM(384/352.8/192/176.4/96/88.2/48/44.1kHz), MQA
Digital Inputs: USB 3.0 type ’A’, High-Speed Asynchronous USB 2.0, (32bit/384kHz)
Headphone Outputs: Balanced 4.4mm, Single-Ended S-Balanced 3.5mm
Power Output: 2.0V/400 mW @ 16 Ohm
Battery: Lithium-polymer 2200mAh
Power System: Charging via USB-C, BC V1.2 compliant up to 1000mA charging current
Power (max): <2W idle, 4W max
Dimensions: 102(l) x 70(w) x 14(h) mm
Weight: 125g (0.28 lbs)
Retails for $149.00 USD
Pre-Order at Audio46 (Available on Feb 15th, 2020)
According to iFi:
Audio46 is the destination store in NYC to demo and buy headphone products.
Stay updated on Audio46 at their sponsor profile on Head-Fi.
