StanD
- Oct 2, 2013
you cannot tell me that my cowon j3 and my fiio x5 sound the same. i cannot care less why. with x5 i can hear instruments that i cannot with j3, using sennheiser ie8, which are easy to drive. does not matter if it is loud or quiet. the test was double, quiet listening and loud listening to some songs, metal. guitars and some drums cannot be heared with j3, no matter what you do.
this is why one should not ever belive that equipment sounds the same. they all sound different.
Unless one has a poorly designed device or it cannot properly drive your IEMs or headphones I wouldn't expect much. If both devices are good and no tone controls are engaged (flat FR) and both have their volumes carefully matched, things should sound the same.
If one of the devices has distortion or a lack of DR (headroom) or other defects, then it will sound inferior. According to Cowon the J3 can only produce 29 mW at 16 Ohms, which means that as the impedance goes up, the power will most likely go down further. On the other hand the FiiO X5 cranks out 460 mW at 16 Ohms. I don't know what the sensitivity of your IEMs are, but perhaps the J3 doesn't have not enough power to properly drive them. Personally I wouldn't buy something that can only deliver 29 mW at 16 Ohms.
You can google up information on "Equal Loudness Contours" or "Fletcher-Munson" to better understand the importance of precisely matching volumes for comparison. You might also look up how human iconic memory works. These might be interesting topics. I have a feeling that their might be a power gap.
