Power strip and cable - Which one to choose to improve audio?
Apr 5, 2023 at 5:28 AM Thread Starter Post #1 of 6
AleksanderWWA89
Poland
I want to buy a new power strip to enhance and protect my system.
Router, DAC/headphone amplifier, PC + iPhone charging will be plugged in.
I heard that the fun starts with products like GigaWatt PF-1e + PowerSync 1.5 m. It costs about PLN 2,500. For me, unfortunately, a lot for today, also taking into account that my entire equipment does not cost PLN 50,000, only 5x less.
I found a Polish company that seems to be an ok price-quality solution. I need help as this is completely new to me. Here I would end up in PLN 1,000
Tomanek TAP5S + Tomanek Power Cable Gold - 230V 1,5m
https://tomanek.net.pl/en/tomanek-t...-jednorzedowa-do-sprzetu-audio-z-filtrem.html
https://tomanek.net.pl/en/80.html
Does it make sense?
Apr 5, 2023 at 7:12 AM Post #2 of 6
Hi, what's the rest of your setup?
Apr 5, 2023 at 7:45 AM Post #4 of 6
If your power is dirty, conditioning can help. But it likely won't be a night and day difference for your setup.
Apr 13, 2023 at 11:27 PM Post #6 of 6
I use a Tripplight strip and with the e50/L30 ii on optical the noise floor is total silence with everything plugged into it. Just don't think a conditioner will help. I use those, because when the material protecting from a surge wears off in 5-6 years, the strip stops working. It's so you really know your stuff is protected or not.
