Soymilk
- Jan 5, 2006
i'm trying to think of some way that i could make it so that when i turn the amp on, the led will slowly light up to full or do a slow pulse once or something like that to give it the sci-fi-ish feel (it'll be lighting up a design on the case). i can't think of anything short of including a microcontroller that controls the led and programming it so that when it gets power it does that though. anyone have any ideas?
this is going into a cmoy. if i plan on only wall powering it, i shouldnt need to worry about any of the potential issues that may come from the basic virtual ground circuit (just the resistor divider) right? as far as i can see, all the potential problems with the vgnd arise from the batteries not draining at the same rate or something like that, just want to make sure.
what would be a good wall wart supply to use? i was thinking of just using the same one as suggested for the ppa on tangentsoft, except that's listed as not available anymore on newark
