Do you mean the wav file on the website ? It is a digital copy I could download it 100 times and it will be exactly the same each time. |
You are listening to a recording of an event (the output of the analog signal), that's copy#1. You are also listening to the recreation of that event on *your* gear (it has to go through your analog outputs, too, to get to your ear), that is copy #2.
The evaluation employs a Pioneer Elite DV-45A as a transport and Yulong DAH1 outboard DAC combination, connected with a Toshiba pure-glass TOSLink Cable |
You have 3 components here that require power cabling-- the transport, the DAC, and the PC recording their output. Where was the "good" cord placed? Why there and not somewhere else? Would it not make more sense to replace *all* these cables, rather than diluting the effect of the one cord you are trying to measure?
Do you mean the digitization process ? |
Yes, a digital picture of your backyard is not the same as the view from your window. Now we are introducing all the artifacts that digital recording entails. We are limited to the 16/44.1 resolution of the event, which is not the 100% resolution of actually listening to the actual analog output yourself. Ask a mastering engineer like Steve Hoffman, he will gladly tell you (what we all know) that digital has a "sound". This sound deviates from the absolutely perfect and is a coloration. You are adding this coloration to the sound when you record the output.
For a digital copy this isnt an issue. I cannot help feeling you are mixing metaphors here. |
You informed me the OP was not simply transferring digital data, he recorded the analog output of his system for this test. There will absolutely be a difference between the actual analog output and the digital recording of it. Also, you are then passing this along to be processed by your own PC, sending that signal back out through the noisy, low-quality analog output section of your sound card. Then you pass that signal on again into your headphone amp for even further distance from the source signal and more degradation. No one should labor under the illusion that they are hearing *exactly* what they would hear by listening to the OP's actual system. Not even close.
For me an Edirol external sound receiver simply taking a bit-perfect USB stream and outputting S/PDIF into an Entech DAC then an M^3 amp and Sennheiser HD580 or Audio-Technica ATH-A700 headphones. Not stellar but surely good enough ? |
Not picking on you, you have what you have, but Entech, is that that ancient Monster Cable litle DAC? Or am I thinking of something else? Not familiar with your headamp.
Folks here, several posted earlier, what does skepticism have to do with it ? |
Placebo cuts both ways. If I expect a certain result (or non result) I will likely get it.
Please dont use the word copy when you mean digitization it is hard to get what you mean and it is misleading. |
Sorry, but you are making a digital recording of sound, namely the output of a couple RCA jacks. It's not that different than taking a mike and making a digital recording of the ambient sounds in your room or the traffic outside. It may sound pretty good, but it's still a recording/copy. the quality of that recording will depend largely on your recording device. How good do you think the computer soundcard's input is? Studio grade? How much time did the designers spend on this feature very few people will use? It may get overloaded during busy/loud passages and distort. Maybe it lacks full dynamic range and compresses the the sound. Maybe it's made of cheap parts that add grain to the sound? Who knows.
What you are doing in effect is "mastering" an analog recording. Big mastering studios that do this professionally to wring every last drop of sound out of an analog source have hundreds of thousands of dollars worth of better equipment than your humble sound card.
If you don't think the quality of digital transfers can vary, compare an antique CD from 1984 to one made today (that has not been compressed to death). The old ADC chips and associated gear were vastly inferior to what we have today. And what the OP is using in his computer is vastly inferior to what is needed to do it as well as modern technology can (which still ain't "perfect".
Just how small are these cable differences, I can resolve down to the sample level, if they are smaller than that then it doesnt really seem worth the bother |
Please tell me what you are attempting to measure and how do you quantify it and what machines are you using to measure it? Please show me the machine that measures soundstage, air around instruments, the firmness of the bass, speed of attack, decay of notes, etc.
You will tell me you are looking at either or both of the two measurable things:
1. The output/peak levels (volume). Well, if a power cord changed peak levels or made certain passages louder and other quieter, that would indeed be a remarkable finding.
2. The frequency response. All those measurements can tell you is, is there a signal present at 1,000 Khz? Is there a signal at 125Hz? Etc. Etc. It tells you absolutely zero, about how those frequencies sound, and how the whole gestalt of frequencies in that area sound together playing actual music.
Man, it's my free night and I keep getting taken away from my chance to do some actual music listening. Bye!
