glunteer
- Sep 15, 2012
anyone know any good toggle switch? My toggle broken and i need other for my audio switcher... (3 way)
I'm guessing any dpdt rated for 3a @ 250vac or 6a @ 125vac should be fine. You can use lower rated values but I like to choose the biggest max spec'd switch. What's important is the length of the protruding shaft (mm) and the overall size of the switch itself. 2-3 toggle DPDT assorted too.
Hummm... Thanks
but you could spend some good brand or model ? (I use a box of altoids)
I bulk purchased off a local ebay supplier for a box of 50, no branding on them, haven't had problems. I purchased a few from ebay beforehand and had no issues with any of the toggle switches either. Do avoid the ones with long toggle shafts, don't have a picture but it's got a flat curvy base end, they are hollow in the middle and snap quite easily. They are used on the Darkvoice amplifiers, mainly the 336SE.
If you use the Altoids box, isn't the ps an external wall wort? Unless I'm missing something.
If so you can get away with a much lower rated switch. You can, most likely find the exact replacement switch at Digikey or Mouser.
Those blue body ones are really common on ebay. No idea who actually makes them, but I have used them inthe past, and they work great.
when i put left, only sound comes from one side of the headphone, but for right is normal...
understand ? ^^
My english is too bad
It's an ONLEDA. Sam brand that Schiit uses for mains power.
Let me see if I can find a DPDT version
http://www.china-electronics.com/Products/Details/MTSp2.htm
Thanks so much
I helped a fellow in the Checz Republic locate a similar one. If I remember correctly I had to get another brand.
There should be a model number stamped on the switch. Please post it.
