- Feb 23, 2011
R2 to R5 Resistor using DIP Socket housing for gain experiment, may be I should using socket for the caps too?
I use OPA2134PA now, but LM358 still sounding a nice result in this second build (at least better than the first build).
Now using Stereo pot. But this pot is too big, since I reuse the tin from the first build and the DIP socket also eat more space, I have to remove the LED.
Adding DC power jack to save battery when I'm at home.
Based on the tutorial, I have to seal the ground from the tin surface. So I use electrical tape and small rubber hose.
What tutorial did you use to help you build your CMoy? I'm using the TangentSoft guide. I like the little holders you have for the resistors, where did you find a pair? I'm waiting to get some wire and I'll see how *bad of a* solder job I do.
