CADCAM
I like my 700's but not the ear pads, I found a seller on "Feebay" that sells replacement velour pads go_me05. The stock pads are 100mm x 57mm, his are 101mm x 47mm. I just got them in and they do fit, a little tight but they fit. The opening is 10mm smaller in diameter (that's about .390 in) I just started listening now and think they sound pretty good, I did not use the supplied foam pad on the inside and they seem to be clearer in the highs, bass is good. I thought these were a little lacking in the highs but not any more. For under $20.00 bucks I'm happy. I will post again after several listening sessions.
Meant to post this under the JVC HA-RX 700 Mods don't know if it can be moved...
