madmonkey
- Nov 26, 2012
which is the most important for sound quailty?
Depends on the budget and what you’re driving. This is such a moveable feast that you need to establish some parameters. Mid-fi vs Totl, iems vs planars, low sensitivity vs high efficiency. I’d never state a fixed percentile absent these criteria.which is the most important for sound quailty?
(Trying to think how to frame this without appearing rude, which is not my intention).headphones is the most important. Chose your one favorite first, then pick the rest later
Yes, that is why I said that one should pick a favorite headphones first, and then worrying about the sources. In which case mine is 800s/anniversary , and as you have known that I have gone through a few systems already(Trying to think how to frame this without appearing rude, which is not my intention).
Given you own a DMP -Z1, I’m not sure you can make this argument. Leaving aside your Stax (requiring their own amp, and the vintage SA5000) your player/source is six or so times expensive than the Senn HD800. Clearly at some stage you decided that the source was significantly more important. At the totl level, this is not an infrequent (or incorrect) position, horses for courses as they say.
To me synergy is the most important consideration
