Dobrescu George
Reviewer: AudiophileHeaven
Info about the unit from official sources :
Elite BAC 400
The PLiXiR Elite BAC 400 power conditioner is the best mains AC power conditioning product for your desktop Hi-fi system. Designed around our concept of Pure Tone*, it naturally cleans up the incoming AC mains supply and improves current delivery to your system. It uses a custom single-winding balanced power transformer to reduce ground-loop current and noise to negligible levels, making the PLiXiR Elite BAC the ideal pick for electrically sensitive equipment like turntables and phono stages.
This Elite BAC 400 is stackable up with Elite BAC150 and Elite BDC, thus, saves space and cabling while delivering cleanest power to your systems. Please refer to Stackable section to customise the stack to best fit your needs. Otherwise, contact us for needed advice. For customer reviews, please click here.
Options are available to upgrade using Cryo-ed Receptacle and Furutech AC inlet.
READ MORE
INPUT/OUTPUT
100Vac~120Vac
220Vac~240Vac
SOCKET
USA Socket
Cryo-ed Receptacle
Schuko Socket
UK Socket
Customise
QUANTITY
$1,490.00
Total Power
400WATT
MAX
Number of Outlets
4/4
USA/EU
Typical Power Amp Supported
30WATT
2 CHANNEL CLASS A/B
Stack Combinations
- Stackable AC power conditioner and DC power supply save space for equipment and cabling. Only one AC power cord is required to power the whole stack. This results in better sound due to neater setup and simpler cable routing.
- Optimized system grounding with balanced AC power transformers. Eliminate ground loop currents, loop area and noise from the power supply. Reduces hum and hiss issues from the system. Increases system resolution naturally.
LEARN MORE
Technology & Craft
Our Elite balanced power conditioners features the highest grade power transformer from Noratel, the inventor and premier toroidal power transformer manufacturer. Customised to our exact spec and with proprietary XQ (eXtra Quiet) technology, our Elite balanced power conditioner provides the best noise isolation, power conditioning and optimal systems grounding for your hifi system in a single package.
LEARN MORE
Other Features
Single-winding transformerSingle-winding transformer dedicated models for 120 Vac and 230 Vac input/output, and each transformer only has a single winding for their intended application for the best performance possible
CasingExtruded, 5mm-thick aluminium casing body. Thick metal top and bottom plates provide an ultra-rigid casing that guards against the sound-degrading effects of mechanical vibrations and protects the transformer from external damage
Master-craftedIndividually built and tested by hand by master craftsmen
Alternative Power Conditioning For
Desk-fi setupincluding a DAC, head amplifier and a pair of small sized active speakers (example ADAM’s Artist 3).
Hi-fi source equipment(Pre-Amp, DAC, Transport, CD/BD Player, media server, turntable etc).
Mac mini style media server PC/Laptoptogether with your audio equipment.
Specifications
TWO VOLTAGE VARIANTS
1. Input 100~120Vac to output 100~120Vac balanced 60hz.
2. Input 220~240Vac to output 220~240Vac balanced 50hz.
IDLE POWER CONSUMPTION
Less than 1.5% of Max power.
POWER OUTPUT
400W Max
WEIGHT
10 kg
DIMENSIONS (IN MM)
230 x 160 x 130
CASING FINISH
Black anodized, sandblasted aluminium
Other Options
For Higher Power Systems
Elite BAC 1500
$3,800.00
Our PLiXiR Elite BAC 1500 power conditioner is the best mains AC power conditioning product for your Hifi system; 1500Watts of Pure Tone* power capable to support up to 250W per channel stereo Hi-fi systems.
Lower Cost
Elementa BAC 1100 - EOL soon.. please contact Sales
$0.00
Our entry level Elementa 1100 power conditioner is designed for source equipment and mid-sized power amps, with 1100W of total power delivery
Elite BAC 400
READ MORE
INPUT/OUTPUT
100Vac~120Vac
220Vac~240Vac
SOCKET
USA Socket
Cryo-ed Receptacle
Schuko Socket
UK Socket
Customise
QUANTITY
$1,490.00
Total Power
400WATT
MAX
Number of Outlets
4/4
USA/EU
30WATT
2 CHANNEL CLASS A/B
Stack Combinations
LEARN MORE
Technology & Craft
LEARN MORE
Other Features
Specifications
POWER OUTPUT
400W Max
WEIGHT
10 kg
DIMENSIONS (IN MM)
230 x 160 x 130
CASING FINISH
Other Options
Elite BAC 1500
$3,800.00
Lower Cost
$0.00
