paara
- Jul 26, 2005
Hi,
First of all I need to apologize for the the lack of knowledge. I have a few questions for you DIY'ers. I am new at DIY audio (not new to electricity
), but I finally decided that I would try to make myself an amp. I choose the Bijou, because it seems like a challenge, and it has gotten great reviews. I have tried to read the 145 page long thread about it, but it is a little overwhelming. I see that glassjaraudio have a kit, but I am not able to buy it because I am from Norway because they do not take non domestic orders. I would really like to make myself a really good amp and wish to avoid buying components that don't match, are of low quality. Since I am new to DIY amping I really need some help. I am able to order the circuit boards from jarrglassaudio, and the casing I will make myself.
I listed my questions below:
1)I need some help finding a place online where I can buy the components needed to build the Bijou amp. Preferably I would like to buy as much as possible in one place.
2)I need some help picking good quality components, what is good and what is not.
3)Any modifications I should get. (like the 370dax instead of the 270dax, better potentiometer etc)
4)The absolute best help I could get, is if somebody had a list of which brand and type I should buy. Like creating a kit similar to the jarglassaudio, but maybe with even better components.
All help will be much appreciated
Thanks,
Stian
Thanks,
Stian
