Please help, I need to know where to find parts for a CD player
Aug 2, 2012 at 10:15 PM Thread Starter Post #1 of 7
Todd R
I am repairing a Xindak SCD-2 CD player that uses a Sony transport
I'm looking for the flat jumper film cable that goes from the Sony laser pick up KHM234ASAA to the curcuit board.
On the cable it says: E228339 AWM 20798 80C 60V VW-1
25 pins
26mm (1-1/16) wide
82mm (3-1/4) long
1mm pin pitch
This will be the short wide cable in the picture.
Since I don't know what model Sony player this transport is usually used in, I can't hunt for a model number and the Xindak company is no help.
This will be the short wide cable in the picture. I have written Tech Cable, but they have not responded.
Any help would be greatly appreciated.
Aug 3, 2012 at 8:59 AM Post #2 of 7
Is the cable within the transport itself or between the transport and board?
If it goes between the transport and board, good luck...it would have been
custom made for the application.
If it is part of the transport, can you post a picture of the transport...maybe
someone can identify it.
Aug 3, 2012 at 9:03 AM Post #3 of 7
It goes from the transport to the board.
It is not custom made, I found the company that produces it, but they have not responded to my question about where to get another one.
Aug 3, 2012 at 9:58 AM Post #4 of 7
What I meant was that Xindak would have had Tech Cable make it for them
for that application.
Aug 4, 2012 at 12:32 PM Post #7 of 7
I found this, but it's non stock.
Nice hunting
I'll try to order it and see what happens.
I'll check some of the other places like Mouser too.
Thanks
