So if we were to address this with some degree of logic and reasoning to counter such claims would it be fair to say that if using cat 7 we would have to live in a world where all residential routers had grounded RJ45 connectors assuming the other end plugged into an imac for example was grounded. Finally can one state with 100 percent accuracy that all residential routers in existence do not have grounded connectors? if the answer to this is yes then cat 6 or cat 7 makes no difference even though our friends on compaudiophile lean towards unshielded ethernet. my only concern is that after buying my intona industrial which has a real effect which is truly real to me and countless others on many other forums that i am not compromising its effectiveness. thanks.
1. So if we were to address this with some degree of logic and reasoning to counter such claims would it be fair to say that if using cat 7 we would have to live in a world where all residential routers had grounded RJ45 connectors assuming the other end plugged into an imac for example was grounded.
2. Finally can one state with 100 percent accuracy that all residential routers in existence do not have grounded connectors?
3. if the answer to this is yes then cat 6 or cat 7 makes no difference even though our friends on compaudiophile lean towards unshielded ethernet.
4. my only concern is that after buying my intona industrial which has a real effect which is truly real to me and countless others on many other forums that i am not compromising its effectiveness.
1. Residential routers are powered by wall-blob power supplies. There is no 3-pin power cord with ground wire. There is no ground, so no shielded connectors. If you used an enterprise switch with grounded connectors, it would ground one end of a shielded CAT cable, which is sufficient. The switch would also have to be grounded, usually via the power cord.
2. Yes, they never have shielded RJ45s for the reason above.
3. When plugged into a connector without a ground contact all CatX cables, shielded or not, behave as basically unshielded cable. I lean to unshielded because it's cheaper. I lean to Cat5e because it's cheaper and easier to terminate, and for residential cable runs, there's no speed advantage (or any other advantage) to Cat6/7. It's just more expensive and more difficult to work with.
4. The only product I can find called Intona is a high speed USB isolator. If that's what you refer to, network cable of all kinds, shielded or not, grounded or not, has no bearing on that at all.
I'm sorry, but unless you're having a noise problem with a USB device, I don't see what the isolator could possibly accomplish. It will not make audio sound better, or even different, as data must pass through it unaltered. All it does is break a possible ground loop, which eliminate noise in the device's audio.
