I have a pair of pioneer se-700 that have the usual broken cable near the ear-cup connection.
The previous owner has already chopped the plug end 10-15cm shorter to fix an earlier break in the cable. When they did this they replaced the original plug with a large gold plug that looks very out or place with the silver and black headphones.
The pads are worn, headband isn’t as bad but will be replaced.
looking for suggestions/feedback on if they should they be kept as close to original or have mild updates?
1) what to replace the cable with?
The original braided one is noisy when touching clothes or table edge. Currently looking at a black 4-5mm diameter soft silicon 4 core shielded cable. So the wiring to the plug will be ready for balanced by just changing the plug.
2) balanced or not balanced plug?
I have a 6.3mm plug on the way that looks period correct and close to original.
3) should I replace the cable through the headband to match or leave it as original?
4) ear pads so far likely just modern sheepskin one that look ok and ar thick enough to be comfortable. Unless someone knows a original looking one.
I have ordered parts from mouser to build 2 junction boxes.
One is set is as close to the same parts as original, the other is all better parts. So I can potentially make a balanced and non balanced version.
While I don’t have any class D amps, but a balanced version removes the common ground between amp speaker channels in the box so has potential for more compatible amps. I have already confirmed my speaker amp is common ground so either works for now.
